JUST ASKING
360 Guy
DELAWARE, USA
A few times, out and about flying, I find myself not paying attention to battery level.
Case in point, last week I stayed out a little too long and by navigating the Minni back I had to land 10 yards away with a gentle landing.
I was lucky this time that I landed this close.
Question is: I would like to set "LOW BATTERY LEVEL" other then the preset 20%.
Is it possible to set low battery level at say.......30% ..........35%?
Again, just ask'in.
TIA 360
Not sure the setting is changeable on DJI drone. If you are so far away that you will deplete your battery, the drone will alert you and try to return home even if you have 50% left. I would just learn to keep an eye on the battery level and if the low battery RTH kicks in....don't interrupt it.
The app will set RTH with enough battery to return, plus a little margin. Let DJI do the work and you will be fine.
