Locating coordinates
Horn Hunter
I'm new to the drone world and have a question. Is it possible to retrieve the coordinates (lat/long) of an object you have just taken a picture of on a flight? I believe they exist somewhere in the photos information but haven't been able to figure out how to actually see them.
A simple way to do this on a Win machine is to go into File Explorer, right click on the image file and select 'Properties', then click on the 'Details' tab.... you should see the GPS Lat/Long coordinates down the bottom.
A batter way would be to install one of the many EXIF tools available..... eg, ExifTool by Phil Harvey, here: ExifTool by Phil Harvey or ExifToolGUI here: ExifToolGUI
Thanks. I should have said I would be wanting to do this in the field with the smart controller if possible.
That can be done with a Mavic 2 Enterprise model and the Smartcontroller.
The Pilot app displays Lat/Long coordinates on screen. In addition, images taken can have Lat/Long superimposed in the image for later processing
By Pilot app do you mean the DJI Go4 app or is there a different app? If so do you have a screenshot of what you are referring to? Thanks for any help you can provide. Being 77 years old I have a little trouble picking up on the technology.
Reactions: WAXMAN
Pilot app is a different app. It’s intended use is for Enterprise models.
I’m currently on the road, standby for screenshots when i am back in the office.
Litchi has this an an option but I don't think you can add Litchi to the SC yet... or can you?
Here we go:
screenshot #1 displays in the lower part the aircrafts lat/long coordinates:
75820
Screenshot #2 (below) shows in the top left side the current date/time an lat/long coordinates superimposed in the finished image (.JPG) in the drone on the SD card.
75821
Note: as said previously, you need an Enterprise model (e.g. Mavic 2 Enterprise / Dual) and Pilot app on your smartcontroller.
Reactions: Thomas B
If you use GoogleEarth, it will post them on your map. Forgot which function it is, “Add”-“Photo” or something like that.
I believe all recorded coordinates are of the aircraft's location and not the location of the "object" to which you refer.
It can also be found with the search function.....
Please Can You Further Elaborate. Not able to do so
Here we go:
I have an Mavic 2 pro, and if you set C1 to camera mode (selection) then it will post the coordinates to the image, and all you need to do is back it up to photo page, click on more options, and they will appear. It was no trouble on that smart controller, but now I have an enterprise advanced and cannot find where to enable that function. It records lat/lon on the display, but not on the image/photo itself. I want to be able to see my object while flying, snap a photo, then go back to the photo, and be able to immediatly see the coordinates. I could take a pen and paper with me, but I feel like I just cannot locate the right toggle.I hope the above was clear I make a lot of mistakes lately.
twixer_bear
