Mavic Mini (A Look Inside)
Regarding the 3v6 pad and gnd. Yes they can be used to power a LED or anything 5 volts
Thanks again Jack one of our techs here
[QUOTE = "djidroneservice, post: 869882, member: 98187"]
[/ QUOTE]
Thank You Very Very Very Much!!!
I understand correctly, is this the FCC version?
And now, as they say in my homeland, "to find 10 differences..."
Please, write the model of chip SKY74? 2N? And, If it is possible, photo RF module can make some better, Please...
[/ QUOTE]
Correct
Yes, i made a separate thread called battery mods... I accomplished a 35min flight as my best so far
Sounds good! Do you have the link of the thread? For some reason I couldn’t find it. Also, what is the specs of the battery you use? Do you think it is possible if we connect the stock battery with extra battery by soldering and carry it on the back or the bottom of the drone? Like people did it with phantom 3 and 4?
That is what I did... Currently I'm using lg 3000mah 18650 20amp cells.... I tried replacing the original battery 18650 cells and the bms died.... I was successful at this on my first go around , so not sure why my second didn't work. If I can replace the cells in the stock battery pack like I did before, 40+ min will be easily achieved. We will see what I come up with.
Here's the link
So guys. What do we learn from those images from the rx?
What we should expect to learn is that there is no difference in hardware- the variations in radio performance between regions are set in factory firmware (according to DJI's explanation).
That would be awesome if you can make it! I saw a guy use 2 extra batteries for Spark (carry on the upper body) and he was able to achieve 40-45 mins, so with MM, I wonder why not? Please keep update if you have more experiment. Thank you!
Man, why you did not see difference??? It is obvious! CE and FCC boards has difference hardwarevise
Reactions: markusd1984
What is it? I didn’t say I haven’t seen it- I said I didn’t expect to. I am interested. What is the difference?
Can someone post the two different mainboards together in one picture please.?
ralph.smith.mckenzie@gmai
