New drone pilot Saint Johns, Florida
floridafeeger
I purchased the DJI Mini 2 SE as my beginners drone recently. Although I am a licensed instrument rated private pilot, I am pursuing the Part 107 exam as a refresher course and to potentially be able to do some drone shots for others. Already have sights on getting the DJI Mini 4 Pro as my future Part 107 drone.
Planes was beyond me, trying turn around RC car in my driveway without crashing it. :rolleyes:
One day I seen somebody flying a thing with a camera on it, OMG.
After research I figured out he was flying a P2V
I was hooked!!👌
Rod .
Welcome Eddie from Co. Cork Ireland ☘️☘️☘️ I too just started out with a Mini 2SE, it's a superb first drone, the technology inside for something so small is nothing short of amazing. There's a lot of people on here with a ton of knowledge, they've helped me a lot in just a month.
Have fun and best of luck
Murph
Since you did not write if you have your TRUST Certificate yet nor how you are pursuing the part 107, I've included all info I have…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum. We look forward to your participation and your view of the world.
twixer_bear
