- Joined
- Sep 17, 2018
- Messages
- 13
- Reactions
- 8
- Age
- 46
No , I’ve switched from HD to normal mode and it does not help. I only get about 600-1000ft and then it’s crap. I’ve read switching your device to airplane mode has helped some, locking the drone onto 2.4, etc, lots of theories. Going to try the airplane mode thing but nothing else has worked. Turn the goggles off and everything is good. They’re are interfering with the signal between the uav and rc some how. Needs to be fixed . Have a $600 paper weight now.I have the same problem beyond a couple thousand feet. Have you noticed any improvement if you switch to 720 rather than 1080?
I was understanding that you only can use the Pagoda when flying a Racing drone. It would not work with a Mavic Pro. Am I'm I right or wrong. Thanks.
Some have said that works but not for me.I was understanding that you only can use the Pagoda when flying a Racing drone. It would not work with a Mavic Pro. Am I'm I right or wrong. Thanks.
I’ve had the same issues and the pagoda fixes it. Remember that the Mavic 2 runs on 5.8 GHz. This was field tested, by me multiple times.Pagoda is used only if operating on 5.8GHz.
There's a bug and there's nothing we can do about it until DJI come up with a fix. Make sure to complain to support.
You can force it not to use 5.8. It helps if you keep it on 2.5 in most cases.
These arguments make no sense to me. Why should I force it to use 2.4 GHz if 5.8 GHz works just fine? It’s not difficult. Attach the antenna, issues go away.It CAN run on 5.8 but typically offers lower performance when doing so, so just lock it to 2.4 especially when using the goggles, goes from appalling to bad.
Maybe they do for you but you're pretty much the only one to report that, for many others they don't.These arguments make no sense to me. Why should I force it to use 2.4 GHz if 5.8 GHz works just fine? It’s not difficult. Attach the antenna, issues go away.
Not sure why the antenna should help. According to DJI, THAT antenna is not used for OcuSync 2
