using a surface pro 2 as a secondary screen
deeavia
GA
is there a possible way to use a surface pro 3 as added screen. I currently am using a iPad with my remote. but I wanted to use a screen for spectator
Surface Pro 3 256GB i5/4th/8GB 1020B​
I think I read once that The Surface devices are Windows based not Android or IOS, so not really compatible.
Does the I pad allow screen mirroring? Maybe that's an option.
an idea is: if your using a drone that has a sdk (not mavic 3/pro/classic) and is compatible with litchi, you may want to try litchi view. when using litchi on your controller, click on the litlle "share" logo on the upper left and click on litchi vue. on the second device (viewers device) download Litchi Vue for DJI drones - Apps on Google Play . then you connect both devices to the same wifi network or to one mobile hotspot and click on the streaming device and you're all set. The viewer can see altitude, distance and speed. in addition the viewer has an option to put his device into vr mode to use with a vr headset.
note: the stream will deactivate if you switch to the dji app so familiarize yourself with litchi before flying.
Kia-6098.111
