VLOS Compare M2E Strobe vs P4P Strobon vs M3E Searchlight
Cookedinlh
Sarnia ON Canada
Here is why VLOS (Visual Line of Sight) is a "no brainer" when you have the new Mavic 2 Enterprise with the spotlight. You will have to go full screen to see. This is only HD (1920x1080) but the differences are obvious. Sorry I should have done this on a tripod . . this was hand held . . but it makes my point anyway. These are worst conditions for STROBON or even the M2E Strobe. Dull sky with low/no contrast clouds but lots of light. A Mavic will disappear at around 12-1400 ft in these conditions without a strobe. You will notice even the M2E strobe disappears when you are moving away from home since the top of the aircraft is facing away.(it was designed to be seen from above. might be different at night). The Phantom with black and white body has 2 strap-on STROBON and is also barely visible at 1400t. But the Enterprise with the spot lights is instantly obvious and unmistakable at over twice the distance as I turn them on and off.
>>> Link to video COMPARE M2E vs Strobon vs Searchlight <<<
ralph.smith.mckenzie@gmai
