5.5 overheating need help
Interested to know if the repair worked and whether the OP still has overheating issues ?
Still waiting on parts from China it seems DJI is the only one who can do this cooling fan replacement so i'm doing it myself. If you check my post ( Crystalsky 5.5 overheating problem fixed ) you can see my temporary repair that is working with no overheating problems
Weren't Dronenerds able to fix it ?
No they wanted to send it to DJI and its only 4 screws and the cooling fan was ordered from Amazon. Dronernerds did recommend that i try to repair it myself with no charge for looking at it.
Good news my new cooling fan came in so I swapped them out and now it's working great. Thanks DRONENERDS and this Forum for good advice.
Reactions: trungduong
Three days of using my CS 5.5 after replacing the cooling fan and still no overheating warnings. Temps here in Kentucky near 100 and I flew it with my Phantom 3 and Mavic Air.
Reactions: Mil
Hi @careless, can you post the link to the fan you bought from Amazon please?
The fan measured 20x20x5mm part number BSB0205HP-00 DC5V . You can find it with Amazon or aliexpress.com with a 3 wire or 2 wire connector. Just remove the 4 T4 bolts that hold the rear cover then use a spludger to pry open the case.
Thank you very much for the info.
rebelsun
