A better way of transferring files from the SRC...
iconicflux
1. Go to www.apkpure.com and install AndSMB
2. Setup a shared drive on a computer that's accessible on the network.
3. Create a target/share within AndSMB pointing to the shared drive that you created in step #2. I suggest using SMBv2/v3 mode and setting the share name to "/<yourshare>".
4. Set the download to controller settings on the drone so that the files are automatically sent to the controller. (I don't remember *exactly* how this was done. I stumbled across it but I did see it in the user guide afterwards.)
5. Go to the controller's photo section and long press a video and you'll see the option to "Share". If you press on that you'll now have "AndSMB" as an option for sharing, select that.
6. Select your share name that you saved in AndSMB.
7. Enjoy the speed of it uploading to your share directly from the controller.
deepdark
