A short explanation of compass function, calibration and errors.
The sky for the info. Especially the pre flight things to check. I have made it point to check the orientation on the map but not the interference screen.
Paul C
Reactions: sar104
Great write up. One related question I had: do you think there is ever a need to use degaussing tools like the "Cfixer" device with our drones? Or is that snake oil?
It's certainly possible for components on the aircraft to become sufficiently magnetized that they cannot be subtracted by calibration. When that happens the calibration should fail, although I've seen a few examples where it reported success but the magnetometer data were still clearly wrong. At that point demagnetization is required, and the CFixer certainly works, although there are much cheaper options on Amazon and elsewhere.
Paul C
The orientation is definitely more important. While it's possible that the aircraft had become magnetized but, by chance, the orientation arrow was pointing correctly, that is extremely unlikely. And if there were local external interference affecting the magnetometers then that will go away on takeoff and, since the IMU was correctly initialized, even if only by pure luck, the flight control will be good.
Good information for me in this situation and my M2 has the latest firmware and i make sure the drone faces same way as the map.Like i say i can do the hand take off with spotter but the landing would be hard even on stationary ship with wave action.I was planning to suspend a plastic tarp 3-4 feet off deck and catch the drone fireman style 2 feet above the tarp by doing emerg shut off.Is this a viable idea ? Boat is 65 feet by 16 foot beam. Or use a wooden or fibreglass boat ? Thanks Guys
BACKGROUND
The aircraft compass is often misunderstood, both in terms of function and purpose, and so it is important to have a clear understanding of what the compass measures, why, and what happens to that information.
At the most basic level the purpose of the compass is to measure the earth’s magnetic field in order to find magnetic north relative to the aircraft heading. At any point near the earth the magnetic field is a single-valued vector quantity described by field strength and direction, and the compass comprises a 3-axis magnetometer aligned with the principle axes of the aircraft (x, y, z), independently measuring the local magnetic field components parallel to those axes.
THE EARTH’S MAGNETIC FIELD
The earth's core is magnetized due mostly to rotation, with magnetic north towards the North Pole and magnetic south towards the South Pole, although the two axes are not perfectly aligned.
The magnetic field lines emanate from the magnetic south pole and return to the south pole in the classic bar magnet pattern, and so at any point on the surface of the earth the magnetic field lies at an angle to the ground, (except near the equator where it is approximately horizontal) called the inclination, and points towards the magnetic north pole.
Since the magnetic north pole and the geographic north pole are not in the same place there will, in general, be an angle between the horizontal component of the magnetic field lines (that point to magnetic north) and the direction of the geographic North Pole (true north). That angle varies by location since, as you look to the north, the apparent relative positions of magnetic north and true north depend on where you are. That offset is called the declination (or variation). So if you also know the declination (you have to know it based on your location since there is no way to measure it) then you can subtract the declination angle to determine where true north is.
Back to the compass - its only job is to determine the direction of magnetic north, and to do that it measures the direction (relative to the aircraft) of the horizontal component of the local magnetic field. If the only magnetic field that it saw were the earth's field then that would be trivial, but the aircraft, itself, has a magnetic field due to internal ferromagnetic components which will, in general, change the direction of horizontal component of the field.
Luckily, magnetic fields follow the Superposition Principle, which means that if two separate magnetic fields interact, the net field vector at any location is simply the vector sum of the individual fields. So, if the magnetic field of the aircraft can be independently measured then, with the assumption that it doesn't change as the aircraft moves around, it can simply be subtracted from the total magnetic field measured by the compass to leave just the earth's magnetic field.
COMPASS CALIBRATION
Measurement of the aircraft’s internal magnetic field at the compass location (it won’t be uniform throughout the aircraft) is achieved by the calibration process since, as the aircraft is rotated, the earth's magnetic field appears to rotate while the aircraft's magnetic field stays constant. The orthogonal rotations in the calibration process allow those two fields to be separated mathematically, and the FC now has the aircraft's magnetic field (the calibration) stored. It subtracts that from the measured field in flight, takes the horizontal component of the resulting field (now assumed to be just the earth's) and thus knows its heading relative to magnetic north.
CORRECTING TO GET TRUE NORTH
However, for navigation the FC needs the aircraft heading relative to true north, since that is the basis of the coordinate system for positioning, such as latitude/longitude. To calculate that heading it has to add the local declination value. There is a common misconception that somehow the calibration process determined declination but it should be obvious that it cannot do that. The orientation of our coordinate system is arbitrary relative to magnetic north and there is no way, as I mentioned above, to figure out the difference between true north and magnetic north with a compass; you have to know the declination separately by looking it up on a map, or calculating it approximately using spherical geometry and knowing the relative positions of the true north pole, the magnetic north pole and your location or, for the most accurate results, using your location with a global model of the earth's field.
The FC does the latter - it has a stored global magnetic field model in firmware and as soon as it gets a GPS position lock on startup it computes the declination (and inclination) from the model and adds the declination to the magnetic heading from the compass. Now it has true heading. That process is documented in the DAT file.
COMPASS INTERFERENCE
Note that all this assumes that there are no other magnetic fields present - only the earth's and the aircraft's. If there are other fields due to ferromagnetic structures, large or small, then the aircraft may or may not be able to detect their presence. The FC has field strength and magnetic field inclination criteria for acceptable measured magnetic field. On the M2, and quite possibly all the models, the total field strength is expected to be in the range 1400 - 1800 µT, as documented here and shown in the graph below. But beyond that, any local field potentially just changes the apparent direction of magnetic north and, if that error is significant, leads to all the common problems after takeoff.
The relationship between compass interference values and magnetic field strength.
Those flight problems are also not obvious in their origin - many people ask why, since very local magnetic interference will go away after takeoff, the problem only manifests afterwards during flight. The answer lies in the way that the FC actually computes heading (yaw). The primary yaw sensor in flight is not the compass - it is the rate gyros - i.e. the heading is primarily tracked inertially in flight, not magnetically. The IMU heading is initialized using the compass heading, before takeoff and after the declination has been computed. Once airborne the compass is only used to correct for drift in the rate gyro data. So if, after takeoff, the magnetic interference goes away, then the compass heading will change without the IMU ever detecting rotation of the aircraft, and the IMU and compass now disagree by far more than the drift correction algorithm can handle. That's the source of all the compass and yaw errors and, since the FC now doesn't know which way it is pointing, it cannot navigate and, unless it quickly switches to ATTI mode, will fly uncontrollably if it tries because it will try to correct for course or position deviations by applying thrust in the wrong direction. That has been the cause of almost all so-called “flyaways”. Any error over 30° or so can cause flight control problems, and anything over 45° will lead to loss of control. Around 90° leads to the classic toilet-bowl flight profile, while 180° causes a simple linear accelerating flight in exactly the wrong direction.
INTERFERENCE CORRECTION
I wondered for some time why DJI didn’t add some code to notice the compass change at takeoff from a magnetically distorted site. On takeoff, as the aircraft climbs out of the local interference but the rate gyros detect no rotation, the obvious correction is simply to re-initialized the IMU heading to the new compass heading. In fact they did exactly that with the second firmware upgrade to the Mavic 2, but previous models still don’t do that. It appears that the Mini and the Mavic Air 2 might have that functionality, but not yet confirmed.
There is also the question of "bad calibrations" - can they happen? I think there are a few scenarios in which that might occur. If the user is wearing something magnetic that may make it appear to be part of the aircraft's magnetic field. Or if the magnetic field is local enough to vary as the aircraft is rotated - that might have a similar effect.
COMPASS INTERFERENCE AND CALIBRATION MESSAGES
A persistently confusing issue is the well known message at power up: “Compass error. Move the aircraft or calibrate the compass.” It’s confusing because it often isn’t even accurate; it can mean several different things, a couple of which are not errors at all:
  1. The magnetic modulus (total magnetic field strength) is outside the expected bounds (error);
  2. The magnetic inclination is incorrect for the location (error);
  3. It is more than 30 days since the last compass calibration (M2 and newer models) - not an error - a firmware trigger;
  4. The aircraft is more than 50 km (30 miles) from its previous takeoff location - not an error - a firmware trigger.
(1) and (2) may be the result of local interference, in which case calibration is unnecessary, and moving the aircraft is appropriate. Or they may be the result of a change in the magnetic field of the aircraft itself, either due to components added/removed or components becoming magnetized due to exposure to a strong external magnetic field, in which case moving won’t help and calibration is required, or possibly even demagnetization of the aircraft.
To be fair to DJI, the causes of (1) and (2) cannot easily be distinguished and so the message is reasonable, but it would be much more helpful if (3) and (4) were explicitly spelled out with a different message.
The only way to be certain about what is going on and to establish whether it is safe to fly is:
  1. Check the aircraft orientation arrow on the map - it should be pointing in the same cardinal direction as the aircraft on the ground;
  2. Check the magnetometer interference values in the app - if they are low (green) then the magnetometer readings are within specification.
(1) should be regarded as an essential pre-flight check - every flight. It would cut flyaways to nearly zero. But that neither of those checks is recommended by DJI, which is rather unfortunate. If the app is going to recommend just one essential check before takeoff - it really should be the orientation arrow which is far more likely to be a problem than an incorrect home point.
If the magnetometer interference readings are high or the aircraft orientation arrow is incorrect then there is magnetic interference at the compass - either external or internal - and moving the aircraft or calibrating will be required. If the interference values are low and the arrow is correct then the message was due to (3) or (4). You can recalibrate as requested but the aircraft is good to fly, and you can actually ignore the message - it will go away on motor start, but come back on the next power up.
Of course the question still remains - why do some models request periodic recalibration? Previous models didn’t do that. Worse still, the user manuals for DJI aircraft have been completely random on the subject in the past - some recommended only calibrating when requested and some recommended calibrating when moving any significant distance. Time was not previously a stated reason. The distance recommendation led many people to assume, incorrectly, that it had something to do with compensating for magnetic declination, but of course that’s physically impossible. So it's currently unclear why this was implemented. It could be that the DJI engineers decided that transport was one common cause of exposure to magnetic fields, or that periodic calibration might help to keep the compass performing closer to nominal. There is certainly no obvious physics-based reason.
Great read! Are there issues with flying far North or South? May be flying past 66°N and I know my compass inclination fails in my hand compass there (from the wrong zone - Australia - haha it’s dragging sideways in the housing! ). But are the compasses in drones more apt to stuff up? Freezing drone aside? Just calibrate as normal and fly? I wonder if you need to calibrate more often towards the poles?
If you go close enough to one of the magnetic poles, there may be some issues but ....
Calibrating the compass has nothing at all to do with where you are or how far you might be from the location of your last flight.
Reactions: itsneedtokno
Could a code be designed to check the latitude and longitude, use sensors to determine the position of the sun, check the time, and compare the information to what the compass is showing? I can elaborate further if need be.
Something DJI could throw in as a failsafe?
Reactions: old man mavic
Good point. Yes - there are issues at very high latitudes. I'll edit the post to mention that.
Reactions: Davros007
In principle yes, if the sensors are able to detect the sun.
excellent research friend, this two things are essential!
I do first one before every take off.
And i dont know how to check second one on MM ( on dji fly app) if i can at all?
BACKGROUND
COMPASS CALIBRATION
Really appreciate the work, Sar104. Nice dry simple facts presented in the kind of linear way that makes sense to me! I agree it’s odd DJI don’t draw more attention to the calibration. They make a great machine but some instructions are lacking. Keep up the good work. Dave
Reactions: sar104
Right - there doesn't seem to be any way to look at the compass or IMU in the Fly app.
Reactions: umanbean and Sallee
My M2P is super conservative in ensuring that the external magnetic field is in order. I know I need to switch the craft on away from steel objects but If I susequently put it on top of my car, it will say compass calibration needed, that's understandable but the problem is, the message will stay even after I have taken it away and it won't take off unless I calibrate the compass. If I switch the craft off and then on at that spot, the message will not re-appear so the magnetic field must be good there.
Just wondering if other M2P owners have the same experience ?
My Mini does not have such behavior, it's very tolerant to magnetic field disturbance.
Super interesting, Many thanks. I am very new to this, and am learning fast, with access to 3 mavics. All 3 played up last week, and did not calibrate well - till i noticed my magnietic iwatch strap! I removed it and all was well again. They are so advanced even a basic thing like a daft magnetic watch bracelet upset them, lesson learned! All good now
Awesome read, thanks!
So there’s really no reason to perform compass calibrations ever now and then “just because”?
I mean, if all the values look good and the aircraft position corresponds with the compass arrow, everything is okay I guess? Even if the takeoff location is a far way from home?
Or should I perform a calibration maybe a couple times a year just to be safe?
If your drone is flying straight and hovering in place, there's no need.
Recalibrating a properly working drone won't make it any safer and being far away from home makes no difference.
Please forgive the ignorance of the newbie in the room, but he has a couple questions ;) .
When you say:
For item 1, are you referring to the white arrow in the image below? This is from the DJIFly app and MA2.
I've seen other people reference the compass arrow, but I can't find a way to get a compass arrow. Is the compass arrow/aircraft orientation arrow/white arrow below all the same thing?
For item 2, how do I do that? I can't find any place to check this in the app.
Thanks for a very informative post, the help and most of all the patience.
When you say:
No - you need to look on the map itself, by selecting the square map icon on the lower left of the screen. Once you expand it you will see something like the screen below. The map is displaying as north up, and so the aircraft arrow icon is pointing south in this view, and that was the orientation of the aircraft on the ground, so its IMU heading was correctly initialized.
The controller icon (the blue circle plus small arrow) is actually not pointing in the correct direction (should be south also) and its location is a bit off too (it was close to the aircraft), but that's due to the issue of magnetic interference from the RC with the phone's compass.
The DJI Fly app doesn't have a compass interference display page, so that only works with the DJI GO 4 app.
Reactions: 809UmUm
piloter
