Advice for a novice drone operator looking for best stills image quality.
Yes I pulled it down and worked with for a while. It handles the lens issue well, pulls down a dedicated profile for the cameras, both P4 and MP2.
No layer support that I can see like in C1 which I use a lot.
Overall a good alternative for sure and I will keep it in my toolkit. Thanks for the suggestion.
Paul C
No later support true but once you’ve corrected the lens distortion then you can ask DxO to dump the file in to C1 or any other editing program.
Reactions: Paul2660
Will it dump out as a dng? That would be excellence.
Paul C
Paul C
Yes I think it does. I have only just gone back to it after a lengthy absence but I’m sure I used to push the RAW files straight across to PS.
I will try it tomorrow and post a couple of screen shots.
Did some work testing. DxO will export a dng to Lightroom with all the corrections you added in DxO. It will also export to your hard drive as a dng same features. Can't find a way to get it to export to Capture One, but have opened a ticket with support.
Not a bad alternative, and will work with DxO some more. For sure it seems to handle the lens correction quite well.
Paul C
Reactions: dannybgoode
deepdark
