Air 2S gimbal stuck
fwright
Mississippi, USA
I had a slow sideways crash at 5 feet. After witch the gimbal is getting stuck when I pan down to 68 degrees. Once there it becomes overloaded and is stuck. It will then jump to 30ish degrees until finally resting to zero. I have normal movement from +24 to -68. It appears to reach 90 degrees in the start up check. Suggestion? Is it work trying to fix to risk breaking it? I have tried a couple of cans of air duster. It also has unobstructed movement when off.
If gimble warmup ok, doesn't seem to be hardware. Have you done the gimble calibration yet? If so, reinstall or refresh the firmware then retry.
jw312569
