Air 3 camera focus
Yazu
Finland
Ok so here's my thing. On my other drones the infinite focus usually are the top 2 bars when using manual focus, but on the Air 3 it seems to be around 6th and 7th from the top.
I'm a person who's had bad experience using auto focus on previous drones , so I've opted to only use manual since then 🤣 .
I actually tested this by going through the focus bar one by one 'till the focus was sharp. It was not sharp on the top bars that's for sure.
This is on the main 24mm camera, the tele lens's infinite focus settles on the top 2 bars.
Can someone else check / test out this. All you really have to do is tap autofocus first the tap to manual.
Hold down the manual focus for a bit and see where the auto focus has set the focus on the focus bar.
You can go as far as taking shots on each focus bar if you will. Kind of just want to check if this a universal thing across the Air 3's or whether I got a bad unit.
Cheers
anton13
