An old guy learning to fly..
Ron0909
Ottawa, Ontario, Canada
Hi everyone,
Just popped in to say hello. My son recieved a Mini 3 Pro from his other half for his birthday so I Just *had* to be able to go flying with him (thats what I told my wife). I picked up a new Mavic Air 2 Fly more combo for a very good deal here in Ottawa. This past Saturday was my maiden flight. All went really well and gradually I started losing the pucker factor. What I did learn was that I am in fact getting old and I can't see as well as I used to. That beautiful Mavic grey is virtually invisible accross a football field. Thanks to this site I've learned all sorts since my time here began not so long ago. I have strobes coming from accross the big pond and some bright skins from Germany and Slovakia. If I can't see bright yellow and black.... Anyways, its nice to meet you all!
Ron
Hi everyone,
Ron
I'd have thought the best strobes are firehouse arc V from the USA. Similarily you are reaching far and wide for skins that are probably equalled in the USA.
That said what is "across" a football field in ft? Realistically I lose site of a mini 2 between 400m and 600m, a mavic 2 doesnt give me much more.
Hello from the Crossroads of America Ron0909.
I fly the MA2 as well and I know what you mean about losing sight of it.
I have strobes to aid with the VLOS and orientation of the aircraft.
20221229_052055-jpg.158801
Have fun with yours and welcome to the Forum. :cool:
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members—many from Ontario--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy. They specifically refer to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
It have thought the best strobes are firehouse arc V from the USA. Similarily you are reaching far and wide for skins that are probably equalled in the USA.
I believe the width of a Canuck football field is 65 yards. I'm guessing time of day and environment make all the difference. Personally I have a hard time discerning whether the drone is coming or going and rely on Fly to see it's positioning at that distance. Yes! I need new glasses :) In regard to the skins...the ones I liked happened to be in europe. Believe it or not, shipping in both cases was cheaper than if I ordered from the states. I'm on a limited budget so the strobes were lumped on top of the raised landing gear, 75cm landing pad and new hard case. My wife will have my left one if I spend any more!. Time will tell but I most likely will follow your advice and get the Firehouse strobes in the future. Here's what I grabbed for skins.
To Hauptmann, MA2 317, Old Man Mavic,
Thank you for the warm welcome, pics, advice and much needed video links!
All my best!
Ron
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
And pass this link onto your Son and wish him a Happy Birthday for me…
Fly On and Fly Safe…
Thank you LoudThunder for the *very* informative post. I just had a peek at the member map as I hadn't even realized it was there. Really cool! Its a far cry from my old php forum way back when. In regard to the Canuck rules, I wrote my basic exam before I even had the drone :) Apart from the really great to know stuff, it almost brings on a sense of paranoia when one thinks about the places a person can and can't fly. I guess many of the laws are needed as there were probably a few boneheads that made it difficult for everyone. I did grab the user manual today and wow! lots in there. Its a far cry from the pamphlet in the box. I like your startup sequence of doing things and will adopt them permanently from here on out. How did you know that aside from unfolding my props and finding a nice clean area, I was in the air faster than poop through a goose.
Thanks again for the post!
Ron
Hi everyone,
Ron
Hi and welcome. I am a tad older than you and absolutely love being able to wiz my MA2 up and around here in the UK. I too struggle a bit with seeing my drone, especially against grey British skies but have had Costco here make me a prescription set of glasses that are off my driving glasses details-they are vari focals and tinted (wrong word, much more technical than tinted) and they are great. Will be interested in how you get on with your strobes (which ones) and skins. Be sure to post results if you can. Fly safe.
Being a long time pilot I thank you for this. sometimes when not flying for a while I forget.
Hi everyone,
Ron
You're not old, I wish I was just 61! Welcome and take your time and never take risks and you'll have a drone for a very long time. Enjoy your time in the sky. If you get lost in the sky, watch your distance from home and see if it is reducing as you try to get the drone back close to you. Never change your altitude when trying this, unless you were low, then first climb up to 200 ft.
Then watch the distance reduce and if it suddenly begins to go further away again, you just passed a mid point, so now you need to see if you must try right or left until it begins to reduce again. Best not to lose sight of it though.
Climb up to 400 feet if required by obstacles in the area. You can also use the map on the controller to understand the orientation of the drone and fly it home.
@Ron0909, 61? You're still a youngster. But I will warn you of one unpleasant aspect of flying as an older man. You're going to glance down at the controller screen and be shocked at the thin or bald spot on the top of your head. If you're easily startled, I suggest always wearing a hat while flying.
boonaga
