I’ve had my
M3P for nearly a year but I’ve hardly used it.
mavicpilots.com
Since you live in Australia and you said you have not flown much, there are specific laws and rules for you to follow, please check to ensure these are current.
Australia’s recreational drone rules are designed to keep you and others safe, on the ground and in the air. Here are the rules you need to know now, before you take-off.
www.casa.gov.au
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 3 Pro
www.dji.com
Fly On and Fly Safe…
