Setting your discharge to 1 days could be the reason. I believe that setting is going to cause you nothing but problems. What exactly does that message say? The image is tough to read.
Most rechargeable batteries only have so many charge/discharge cycles so you might be shortening their life by discharging after 1 day. DJI's hardware is pretty solid so I will go out on a limb and say they set default to 10 days because that was the best setting for their batteries. The battery manual is found here: https://dl.djicdn.com/downloads/mavic/Mavic+Pro+Intelligent+Flight+Battery+Safety+Guidelines-EN.pdf
I had that myself, yesterday ... first time after updating to 4.1.22.
It appeared when I turned the MP on.
It cleared after resetting the discharge time and a complete discharge/recharge ... though uncertain whether if it was the recharge or resetting the discharge days that cleared it.
Should have done them one at a time. LOL
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
