battery result
teccer
wilts uk
I had a flight with my mini2 yesterday, first flight 7 minutes this is what airdata shows
then using the same battery at 60% had a 2 minute flight 4 minutes later this is what airdata shows
why the difference?
That shows the number of minor deviations per minute during the recorded flight... cell deviations aren't anything constant, it will fluctuate & it will depend on how much amps you command out from the battery pack.
Just looking at 1 or 2 flights say absolutely nothing... hundreds is needed to judge if it's any bad pattern regarding cell deviations with a single battery pack. And furthermore... this is minor deviations (up to 0,01v), it's perfectly normal & nothing to worry about. When you start to get deviations above 0,1v on a regular basis or when the battery is stressed (like very cold or hot ambient or in Sport mode) then you should start to think twice about using that battery for airborne tasks.
thanks for explaining this
xa_
