Beach Flyers
Starz
Arizona
Something to be aware of. A friend ran across this M2 pro that needed a home. Haven’t determined what issues it may have at this time and would not send this in the air until until I find how much debris is hiding inside. The first observation is the poor thing obviously has had some beach time. I will be opening it up to see just how much sand is inside. More pictures to follow. The goal here is to inform the potential beach flyers of the drawbacks of of flying off a bad takeoff location.
Reactions: 4006448 and Romi
Bottom cover removed. Doesn’t seem to be from below the tide line but this shows some of the places the sand can hide.
Reactions: Yorkshire_Pud
Thanks for sharing. This is good to know.
I guess the question that comes to mind is, does it matter?
Any drone that has been flown a lot with ground takeoff and landing, and is not carefully cleaned regularly will have all sorts of dirt, dust, grit in all of these places.
Point is, it's not just sand and beach environments.
So long as it's in static dead spaces, I don't see any "problem" other than tickling the OCD god. Probably a good idea to blow the drone now and then with a can of computer keyboard dust spray – I do now and then when I think of it – but if the sand isn't in articulating joints, motors, or other moving parts, don't get too concerned. Cleaning those voids and various edges and flanges is more aesthetic than functional.
In any case if it works fine and has no problems, snatch it up... Mavic 2 Pros are worth their weight in gold, being the best foldable that still works autonomously with Litchi et al.
static dead spaces
The issue that I have in my little brain is that whatever debris gets into the system can migrate to places it shouldn’t be. The lube that DJI uses in the rear swivel joints is a great collector of anything that gets close to those areas. It then acts as sandpaper in that joint. Then you have a cooling fan to consider as a means for moving incoming material into places that it shouldn’t be.
Well, "shouldn't be" is what I was getting at. Is it a problem?
I have no doubt that the majority of owners pay no attention to this, yet I don't recall anyone posting problems because of it.
It simply may be that, what you theorize does not, in fact, happen to any detrimental degree. Doesn't seem we're seeing postings over the years with failures traced back to what are essentially dirty aircraft. Perhaps the engineers considered this in the design, so crud accumulating in those places is benign.
I don't know. I just know that if it causes problems, it's rare insofar as MPDC posts are concerned.
Regardless, I'm one of those that does keep mine clean.
The Wet Suits do a pretty good job of keeping the Sand / Salt out of the drone
as well as protecting the sensors.
Phantomrain.org
Gear to fly in the Rain/Snow and Protect from Sand / Salt
I often see references to “blow out the dirt”, presumably with compressed air. Would it not make more sense to use a vacuum first, to suck some of that dirt out?
Reactions: Capt KO
I haven’t found a vacuum that has the power to remove what can hide in these aircraft. No real access to get where this material can hide.
This dirt material came out of one motor and the inside of a front leg on a M2 pro that ran into a mud problem. Used a very thin pick and compressed air to remove.IMG_4895.jpeg
Yikes! That is scary.
Well, my point was don’t force dirt into every micro crevice with compressed air, that would be counterproductive.
spencergotty
