Beginner DJI Mini 3 Pro pilot
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Beginner DJI Mini 3 Pro pilot​
Hey DCWay,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in British Columbia, there are specific laws and rules for you to follow, please check to ensure these are current.
As a New Mini 3 Owner, we'll look forward to all those beautiful Photos and Videos from your neck of the woods.
As a new Droner, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Pleopard
