After you select active track tap whatever or whoever you want the drone to lock onto. It will turn green and hit go. Then your options will open up.
Or draw a box around it and then click the "GO" box. I agree that this is probably the part our OP is missing
OK I am having a similar issue with the spark - it works fine if I use my Ipad but when I hook up my S6 and try to go into IFM I don't get the options on the bottom of the screen. I checked the setting in the go app and they match the Ipad exactly.
Baima
