Charge New M3Pro RC Pro Controller
If the cable connector and the RC Pro charging port are the same, then yes. I don't have either but most likely both are USB-C... even the venerable Apple iPhone (15) finally joined the rest of the world and started using USB-C, as announced yesterday.
May not be the optimal solution depending on the output of the smart controller charger, but if the cable plugs in to the RC, it'll work.
Update.
Yes you can change at full speed.
The batteries & the M3 Pro RC Pro Controller
With the older Smart Controller power supply.
I can also do full speed recharging using my Skydio 2 Power supply.
I only get a half speed recharge using a portable power supply.
Hope this helps.
Britt
