3 Circular rainbow
Sadly I didn't use auto bracketing with the component images, and I need to use a better stitcher than Adobe, but circular rainbows are an awesome sight you can really only effectively capture with drones:
You could try PTGui, it gives more options for the projection.
What altitude were you at?
Reactions: landscapetog
Was up around 100' AGL vs the launch point on a ridge, probably 300' AGL where the drone was hovering over that same ridge. The valley below is much deeper than that, dropping around 2000' elevation from the ridgeline (Pisgah NF, Max Patch vicinity).
Reactions: Dronecation
Circular rainbows are a common phenomenon when cloud flying in airplanes. It happens anytime the sun is directly behind you. You then fly into your own shadow. It's really a cool thing to see, but it requires instrument flight clearance, which, sadly, so far, we can't get with drones. These are excellent shots.
Reactions: passedpawn
Thanks Russ!
I've also seen glories which are exactly as you describe, much smaller and less brilliant circular rainbow-like optical phenomena versus the more traditional water-droplet rainbows as shown here.
Sundogs are also not uncommon, and other ice-crystal optical phenomena often seen with high-altitude cirrus clouds.Screen Shot 2024-02-21 at 3.57.40 PM.png
2024mastermind
