Compact ND lens filter case
I just finished this case for my PolarPro Mavic filters. I bought a Pelican compact memory card case *snip*.
Thanks much Rodzilla! I modified your plans to make a 10 pack carrier because I already had 8 filters. I used the same homemade cutting tools. The 3/4 copper end seems a bit too big so it was larger than the paper cutout. That made my cut-outs a little sloppy but still serviceable. I may make new inserts if I can find a tighter fit cutter.
*Update*
I found that I bought the wrong kind of reducer from 1/2 to 3/4. There is one that fits INSIDE the 3/4 copper pipe and one that goes around the outside. I had bought the latter and today got the reducer that slips inside the 3/4 pipe so I will try again to cut it out! The below photo is the newly cut foam!
Reactions: Rogue002
I purchased the 2mm and 5mm foam sheets at the local Hobby Lobby. I got the 7mm on eBay. Good luck!
Any idea what kind of foam you purchased? I plan to order materials to make a clone of your case, it looks perfect!
Thanks!
ryanhafeman
