Compression and bitrate
Danmickread
cb90hw
Hi,
I assume that the files created from the mavic mini are already compressed to some extent with a bit rate of 40mbps?
If my original file from mavic mini is 2.7k at 40mbps and then I edited it and then wanted to render it with no loss of quality from original, so I have a master no worse than original, would I just encode it h264 with same bit rate as original?
For uploading to YouTube i could either use this master file or if I did want to reduce the file size what bit rate for 2.7k would you guys suggest?
If I wanted to create a HIGH quality 1080p version from the master as well, not necessarily for YouTube but to have a version to play on my own phones/tablets what bit rate would people suggest for this too.
Thanks in advance.
Dan
Hi,
Thanks in advance.
Dan
This is the bitrate of the MM with the different settings, 1080 25 - 60 fps and 2700 25 and 30 fps:
survey-rich
