- Joined
- Oct 12, 2016
- Messages
- 482
- Reactions
- 194
- Age
- 58
Dronebow take 3....
Ok, I had posted previously about the drone I took to Colorado and the bad jello or vibrations I had there. It was cold and some said they thought that was the issue. Others said I needed ND Filters.. The cause was not really defined since I didn't seem to have issues like that later.
I flew it again this past weekend. Temps were about 50+ degrees. Wind is minimal. I'll have to post the video when I can cut it down because it's about 2gb. Half way in there were what looked like on my FPV as video feed distortions. Like you might see if the signal is bad or something got disrupted momentarily. It happens for a few seconds and then seemingly goes away.
Well in the actual video feed it's there. It's inexplicable to me. No wind, no weather, should be no issues. I'm thinking this is the 3rd time I will need to send this back to DJI for an RMA... I'm a little disenchanted to say the least.
Also noted that I started having signal disconnects at about 2000' in an area where I only had some trees in LoS and I was 200' up. Never had issues like this with the P3. It was solid.
Firmware is 1.3.02.
Thoughts welcome...
Firmware is 1.3.02.
Thoughts welcome...
