Delay with iPad Mini, FlyApp and Mavic 3
COffe
Hi guys,
Is anyone else using an iPad Mini 4 with the Mavic 3 and the FlyApp?
I have a weird issue: Everything seems to work fine, but then I start my M3 and suddenly I'm getting a delay in the video transmission on my iPad Mini 4. It can be up to a second and a half. But it is not constant. The delay seems to be varying between something less then a tenth of a second up to a second and a half.
I was using h265 with DLog on the copter.
Chris
Hi Chris,
I think, the "old" iPad 4 has problems to keep up with the quality of the video feed, coming from the drone. I once had the same problem with my Mavic 2 Pro and an iPad Mini 3 after an update (I'm not quite sure if it was a App- or Aircraft update) but had to upgrade my Mini to have sufficient processing power to view the livefeed from the drone. Recording etc. continued but I had stutters or longer delays in the playback / livestream.
You can test that by recording and see, if the recorded material also has delays on the corresponding spots.
Hope that helps and good luck
Chris
Though it is still on the compatible list of DJI for the fly app 1.5.1...
Well I guess it is time to think about an alternative.
iPad Mini 4 doesn’t cut it any more especially with Fly app. Old processing power now. Time to update, like me having tu use my IPhone 12 Pro until I can afford newer Mini IPad.
Rhinodrone
