- Joined
- Oct 11, 2017
- Messages
- 2
- Reactions
- 0
- Age
- 47
I'm a new Mavic Pro owner, and I was just wondering why my drone will only fly 2200 feet away before I lose connection. I thought these things can go 4 miles or something.
Howdy from Wyoming fairwaychris, welcome to the community, plenty of fine folk and excellent information here.I'm a new Mavic Pro owner, and I was just wondering why my drone will only fly 2200 feet away before I lose connection. I thought these things can go 4 miles or something.
The 4 miles are "under ideal circumstances" and your results will vary. Trees, buildings, power lines, and terrain can drastically affect your connection. From my house I can fly further to the South than to the West because there are some high-voltage transmission lines to the West.I'm a new Mavic Pro owner, and I was just wondering why my drone will only fly 2200 feet away before I lose connection. I thought these things can go 4 miles or something.
As others have stated, this is completely dependent upon a large number of factors. I have personally flown a P4P and I2 to 20,000 feet away from home point, but that required a very open area, proper antenna orientation, etc.I'm a new Mavic Pro owner, and I was just wondering why my drone will only fly 2200 feet away before I lose connection. I thought these things can go 4 miles or something.
I've found the more houses and built up the area, the less range you can get. Probably from all the extra Wi-Fi.
I find getting out into open space increases your range significantly.
I often jump in the car for a 15 minute drive into the country side and get some hight and you have all the range you could possibly want.
This is my practice as well. Driving to a higher elevation allows for a much greater line of sight while staying within AGL limits. In other words, you're looking down on your drone as opposed to up. LOS is never an easy rule to follow when wearing DJI goggles, its just too darn adventurous to fly to the outer boundaries.
I've experienced several instances where my drone initiated a return home when my power consumption was still adequate to get back, and signal was still strong, but I always err on the safe side and let it do its thing.
I've landed with anywhere from 10% to 25% power remaining, so still trying to understand the system.
A couple things I've discovered in if returning home in a tail wind is that it requires power to reduce ground speed. The same goes for descending. Therefore, due to the complexity of the system and the constant stream of variables. I let the system tell me when its time to head for home.
Having said that, I feel its good practice to practice emergency landings as far away as possible. It just good practice should you get out toward the boundary and the wind shift making a RTH impossible. Landing in a remote field near a road is a easily done with a little practice.
I regularly get over 20000ft checking my cows all stock
