Hello all,
I have searched the forum and google, and have found only sparse issues regarding the subject title. My S5 and older DJI software works fine without pixelation on the video transmission even up to 2000 feet away. After I upgraded to the 4.2.6 app and associated firmware on the Mavic, now, I can't fly my Mavic without video pixelation. I can be as close as 10 feet, and pixelated video transmission still occurs. I have done the following to try to fix the issue:
1. Uninstall and reinstall DJI 4.2.6 app two times with no success.
2. I have tried to select varies transmission (regular mode/smooth/HD mode, 10 mhz, 20 mhz), and that did not work either.
3. I have not modify the cache location or where DJI saves the image by default (phone and not SD Card on phone).
The issue comes and goes. Within the first 5 minutes, everything is fine. Then into flight (recording or no recording), the video transmission gets pixelated and I have to press the RTH button. Sometimes, the pixelation starts within 30 seconds of flight. Sometimes, it is right away when I connect.
Could someone make any reasonable suggest as to what I can do to mitigate the pixelation issue? I had a Samsung Tab S also, and that tablet will not work with DJI App. Pixelation starts as soon as you connect tot the Mavic. That has happened with the old version and new version of DJI.
