DJI Batteries and Cold Weather . . .
BigAl07
Administrator
Staff Member
Western NC, USA
Some of you may know Ken Booth who was originally active with DJI and very involved in their Battery Design. :
(the below is 100% from Ken Booth)
"First please look at the attached image, this should really explain all you need to know on how cold effects capacity. Once you understand this, most of the other pieces come together.
Now that we understand what cold does to capacity let us talk about overall discharge.
Most of us know that C is based on overall capacity, so if your capacity goes down, so will your C rating. Unfortunately, DJI does not use batteries that have much overhead, this is mostly due to keep the weight down at a certain price point. So, when we start to pull from this cold battery a few things can happen. If the pack has not been preheated, it will start to preheat itself. You are probably asking; well if that’s the case, why do I have to worry about preheating?
Well, if the battery is too cold and C rating has been affected, it will not be able to supply enough output (required C), going over its current C rating due to loss of capacity. This starts heating the pack up rapidly. Which in turn makes the pack quickly go past normal operating temperatures, which will also decrease output. This will cause immediate damage and more than likely a cell failure under extreme conditions. This is called thermal runaway.
The next thing that can happen is part of the smart logic and safety features of these packs. Since the cold does affect overall capacity, this could kick the overcharge protection in and start a self-discharge of the pack(s). In theory this is good and prevents possible damage or even a fire but can also play with the SOC (state of charge) that calculates the current charge state. While the logic is pretty darn good its not perfect. The percentage could be off as much as 20-30%. The same goes for an automatic timed self-discharge, you NEVER want to fly a pack that has been allowed to self-discharge. I would also highly advise to never fly ANY partially discharged pack unless that pack has been used that same day.
So, what can we do to help or minimize these issues?
Preheat packs in cooler weather. I would say anything below 55F you should start paying attention. One easy way to keep packs nice and warm in colder weather is dry rice and an ice chest / bag. Take a few pounds of dry rice (this depends on how big of a cooler you have) and place the rice in a large zip-lock bag(s). Microwave the rice for about 5-10mins or until very hot. Place the rice in the cooler. This should keep packs warm for most of the day. I prefer this method since the rice is reusable and does help with small amounts of moisture as well.
DO NOT Keep full pack charged for more than 24, 48 hours MAX! Any type of lipo does not like to be kept fully charge for a long period. This is not just for smart packs, any lipo will degrade over time if kept in a full charge state. Signs of this can be shorter flight times and possibly puffing (gassing) in extreme cases.
DO NOT over discharge your packs. Anything past 20%, consider it a reserve. If you commonly go past this 20% mark you will shorten you packs life. This is extremely important during extreme temps, both hot and cold weather.
DO NOT expect the same performance. In cold weather, even after preheating. Some craft keep packs warmer than others. Be easy on the packs, especially at the start of the flight, even after preheating.
Stop and hover. This is important for ANY time of year and should be included in you SOP. When you first take off, stop and hover for at least a minute. Even prior to a mapping run, take off and hover for a minute before the start of a mission. It is worth that 1 or 2mins less of mission time. Check all controls and watch the behavior of the craft. If you start to see drifting or any odd behavior, that is your clue to land and diagnose the issues. You would be surprised at how many logs of failures I have seen and the first thing the operator does is a punch out. This is probably the worst thing you can do with these types of craft. When these craft are not well, they usually show signs at the begging of flight. I simple hover with some minor control inputs can do wonders at showing a healthy or sick craft. This also allows the internals of the craft and packs to start warming up properly.
Check voltages and balances in the app and not percentages. Always have voltage options turned on. This is something to check when you are doing the hover and control test at the start of flight. Open the battery menu and check each cell, make sure everything looks good. Make sure you do not see any cells dropping rapidly and or voltage issues.
Voltages. A freshly charged pack should be around 4.2-4.3v per cell. A clue to a bad SOC is a percentage showing 99-100% but a much lower voltage. Once again, during that initial hover period check the cell voltages or overall voltage. If you see something like 3.9v at 99-100% charge, that pack either has a SOC issue or the pack is not healthy. If you do see any anomalies, do not risk it! Land and swap the packs.
Maintenance. With smart packs there’s only a few basic maintenance items you must be aware of. For older packs such as the p4 pack I would still recommend bringing these packs down below 10% every 20-30 flight or after long periods of storage. When you go past 20% make sure you are not flying hard and only hovering at a low altitude. The key here is to drain the pack as slow and gently as possible. What this does is perform something like a soft reset (calibration) on the SOC counter. Now if you are constantly using packs and not abusing them, you more than likely do not have to worry about a calibration. But remember long period of storage might require this to get the battery back to calculating accurately. After long storage periods its always best practice to monitor the pack during the initial flight. I know I am **** but if a pack has sat more than 3 months, I fully charge and then hover for the entire flight down to 20%. During this flight I am constantly monitoring the packs performance via the battery window. If the pack is not well this will usually show signs, especially voltages and balance issues.
Newer packs such as the m2 and enterprise models should not require this and most issues we see are due to storage charge and temperatures. With that being said, there are times a good battery calibration can bring back unhealthy packs in these new generation smart batteries.
I know I have probably missed some stuff, but it is simple. Keep packs above 60F in cold weather, not push them hard, do not keep batteries fully charged for long periods of time and do not store while fully charged in cold conditions.
I know for first responders, a lot of this is hard to do but you must develop a battery maintenance schedule. Batteries still need to be cycled. I would suggest at least twice a week down to 50% if kept at full levels.
One more thing, please know that warm weather works in a very similar way. You do not want packs starting off too warm. Try to keep packs below 90F prior to flight. Also, the same with storage, never store fully charged packs in extreme temperatures.
I have tried my best to not get too technical and put it laymen terms as best as I could."
(all credit goes to Ken Booth)
Excellent information, I never normally have the cell voltages displayed, but will do so from now on, one bad cell will stand out a mile & could have far more serious consequences on a longer flight.
That should be required reading for anyone new to drones and LiPo’s. Very good advice.
Yes it should be but it will not be long before there is another post asking about it.
Yep ... all is good there. But some crucial real life considerations is missing though ... all batteries aren't new forever & they aren't cared for meticulously by all users either.
A battery that can withstand a full elevator + throttle command in 14F degrees (-10C) operational temp. without a major voltage drop when relatively new the first winter ... suddenly generates cell failures with following force landings the second winter. It's not only keeping the batteries warm that matters.
Having operated drones since 2012, I’m very conscious of battery health & am used to cycling batteries like for the I1P. Ken didn’t mention keeping the terminals clean which also seems quite important.
Also I have noticed that drones always draw down on one cell more than others during high demand, even with healthy batteries. It does recover quickly & the logs show the voltage being reduced fairly evenly overall. Not just on the M2P but also on the I1P & with different batteries. This used to bother me but it seems to be pretty normal. I would have liked Ken’s opinion on this. Thank you for recycling this article, very helpful for one living in Quebec. BTW another way to keep batteries warm is to stuff them into yr trouser pockets.
...Also I have noticed that drones always draw down on one cell more than others during high demand, even with healthy batteries. It does recover quickly & the logs show the voltage being reduced fairly evenly overall. ...
I all logs I've looked at, both here at the forum but also from my own crafts it's nearly always found that either the first or last cell in the battery is the lowest voltage wise & makes up the total cell deviation over the whole battery. Have read that it has to do with the electron/current flow direction ... don't know enough to explain why though, but it's normal as you say.
The voltage drop as such isn't dangerous, instead very normal when the amp draw increases ... it's when the drop becomes to deep it's risking to accelerate the degradation (by permanently increasing the internal resistance) ... & when it comes to DJI crafts, going under 3V & initialize a sudden force landing in a perhaps not so good position.
We keep ours warm using a COOLER and portable hand warmers (either iron oxide or the chemically rechargeable units). Works like a charm and we've flown like this for over 12 hours at a time in freezing temps. I find the OPERATOR limitations for cold weather to be the BIG factor LOL.
I joined this forum last night. This is the very first post I have read. Fantastic post. Thank you very much for the effort, it’s going to help me in my management.
WELCOME to the forum :)
There’s some good information however running a battery at cold temperatures does not destroy the battery. If it did there would be hundreds of thousands of electric cars with bad batteries. I own two electrics since 2014 and use them year round and the sit out in sub zero weather all winter. Cars use the same pouch cells as drones.
The only thing to be concerned is charging lithium in sub zero weather which is not a problem with drones.
there is a lot of Myth out there on lithium which is 90% just that myth. Just fly them and charge. There is two buffers in place so you can’t overcharge nor over discharge the batteries. I have every DJI made all with original batteries. I never lost a drone from a battery failure.
Mike
...there is a lot of Myth out there on lithium which is 90% just that myth.
...I never lost a drone from a battery failure.
...Just fly them and charge
Yep ... have read your statistical secured claims before, the only caveat in your claim though, is that you only use your own experiences & put aside all other that gets reported & verified through the flight logs here in this forum, start to monitor this place to get a bigger picture for instance --> Mavic Crash & Flyaway Assistance
Both battery swelling, batteries that can't be resurrected after a too long period of storage & voltage drops below 3v with following forced auto landings ... exists & aren't just myths. Battery failures aren't solely dependent on cold environments ... but cold make it more likely to happen.
While I appreciate your concern for lithium batteries, most of what is published here on this thread is in error.
My use of lithium expands further t han with just hobby drones. I have been installing Lithium in Military drone equipment since 1992, I have a pretty good handle on their chemistry and use. In addition, I provide consulting services for US lithium battery manufactures such as Lithionics Battery, to include designing dozens of Lithium systems for RV's. I included a few links to some of my more recent lithium projects. Regretfully, there is entirely too much myth regarding Lithium batteries and all their self-proclaimed problems.
www.rotory.com
www.rvvolt.com
...most of what is published here on this thread is in error...
Yeah ... have heard you mate, care to specify a bit more into details instead of just claiming most is myths & most of it is in error?
Testimonial is I have 1-2 each of every model DJI offered as well as dozens of other drones to include almost every electric helicopter made all with original batteries. With modern drone battery technology, the only thing the owner needs to do is charge it - fly it & recharge it. Since every pack has a battery control module onboard, there is no way you can over or under charge it nor abuse it temperature wise.
Regards - Mike
Regards - Mike
So again you use your own experiences in order to claim that nothing will or can happen with LiPo batteries ... furthermore no one have claimed that the problem consists of batteries getting over or under charged.
LiPo batteries don't last forever ... it's as simple as that. The internal resistance increases due to a number of reasons which will regulate how prone they are for voltage drops. If cells goes under 3v they becomes unstable & the chemistry inside breaks down which again increases the internal resistance. At 3,7v a LiPo cell is most stable & can be long term stored without to much degradation of the chemistry.
And as you yourself have said earlier ... LiPo batteries are less effective when cold, meaning they have an increased internal resistance. This make them more sensitive for higher sustained amp draw ... & if a DJI battery is pushed in a condition like that, cells can fail & fall under 3v which leads to a immediate forced auto landing.
Below is facts from a recent flight log from a Mavic 2 Pro flown hard in sub freezing temperatures ... cell 3 failed & dropped below 2,5v (yellow graph) & the craft started to land. The pilot managed to negotiate the craft to a safer landing spot on the side of a road & salvaged it.
In the cutout from the log event stream pasted into the chart below ... you can read about what DJI thinks of the situation.
(click on the chart to make it larger)
Your overwhelming yourself with unneeded documentation and myth, unlike systems which we design for military applications and large scale 30 kw systems for RV's, the hobby battery is a simple device that needs no fondling, handling, cycling. The only thing that happens to Lithium is a small loss of capacity. The same pouch cells used in our drones are used in some automotive applications, where the life expectancy is 30-40 years. In fact, batteries taken from old electric cars from 2014 are repackaged and resold again. Power grid companies purchase old lithium batteries where they are installed for back up power when the grid goes down. Just fly your hobby drone and don't worry about the battery its one of the most secure components on the drone.
Regarding your pretty chart, it's common knowledge that lithium power declines with colder temperatures there's nothing new here to look at. The only precautions you need, is to avoid charging a battery in freezing temperatures. There are hundreds of thousands of electric cars which are used every day in cold weather with no problems.
Regards - Mike
Reactions: TnDronePilot
volidas
