Drone flying in Rotterdam
Hi Joost,
Thanks a lot for the info, very helpful.
I'll take you up on the advice. I'll be checking into the hotel at 8am, so weather depending I might just make a beeline down to the park before the crowds show up and have a little play.
Off to the country side in the UK next so I can be a little more adventurous.....this is literally going to be my first flight as here in Bangkok there is literally no where to fly a drone.
You’re welcome mate! Don’t expect too much of it, but if you’re desperately looking for a place to fly, then this is a good spot. Enjoy your stay and have a safe trip! 👍🏻
Hi Everyone, I just picked up my first drone, DJI Mini 2 and will be passing through Rotterdam in a couple of weeks. I would love to get down to the port but since having a scout around online it looks like for the most part its all a no fly zone along with the rest of Rotterdam. Has anyone got any nearby suggestions or pointers before I start going through the license process?
Thanks in advance and look forward to asking everyone a lot more questions in the future....Northampton and Norfolk will be my next stops 😁
Welcome from the Hampton Roads area of Virginia, USA. I too am a Mini 2 Flyer and I know the excitement of flight.
Some Advice…
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby."
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page Mini 2 User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Downloads - DJI
Happy Droning
xa_
