Drone License commercial
@Gruppe8 firstly welcome to the forum
with regards to the Mini 3 pro drone the minimum you need to do is register it with the CAA and display your operator ID number which lasts a year, on the outside of the drone, but while you are at it you may as well do the flyer ID test which is free and lasts for 5 years ,also a good idea is to join one of the model flyers organisations such as FPV UK or BMFA which also give you third party liability insurance as part of their membership ,the need for commercial training and qualifications to be able to monetise you images for inclusion on the internet , no longer applies now ,as long as you are only flying in the open category
Thanks very much much appreciated
Reactions: old man mavic
Thank you
Thank you
thank you
Reactions: MA2 317
Welcome to the forum from the outback of Australia. 5 years of stock to work through, when do you find time to fly? 😀
Regards
Lol, if i stopped taking images now the backlog would take 5 years, so the rolling ball keeps rolling, I take as an example aviation images at London Heathrow, I can easily shoot 300 images in a day say 220 will be suitable, I can edit and upload 10 a day so 22 days work created in 1 day shooting :)
  • Haha
Reactions: Gagey52
I am considering buying a dji mini3 pro, for recreational use in England,
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Thanks for the good advice
Reactions: LoudThunder
Jose Molina
