Drone Lover
Welcome to the forum! :)
Hello! I am a drone lover :) A female Mavic and Mini pilot
Would love to see some footage from your neck of the woods. I can't imagine looking in any direction and seeing amazing mountains, valleys and other vistas. Our world is so flat where we live - the local garbage dump is the largest hill within 100 km.
Since you live in Switzerland, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Check out (on this forum), posts from Maik Kellerhalls. He is a Swiss native and has done, arguably, some of the best work on this forum.
Reactions: RodPad
Welcome to the forum. We look forward to your participation and your view of the world.
AVI Drones
