EXP settings?
m4v1c
I accidentally messed with the "EXP settings" and have no idea what it means or does to the drone. If someone could give me the default flight mode graph settings or tell me how to reset the EXP to default that would be much appreciated!
I'm currently on 0.21 (Throttle Up), 0.10 (Rudder Right), 0.85 (Forward/Right). I honestly have no idea what these numbers mean...
Thanks!
The default settings are all 0.25.
Thanks!
Short version, EXPO basically makes the control gimbals (the left and right sticks on the controller, yes also called gimbals) more or less sensitive around center.
Reactions: m4v1c
Ok sounds good, I'm assuming that I should keep each EXPO setting to be 0.25 since I'm a new pilot? Is there a specific EXPO setting that you all would recommend to new flyers?
Thanks!
fredguillot02
