- Joined
- Oct 5, 2018
- Messages
- 23
- Reactions
- 14
- Age
- 21
MA Drone Pilot" data-source="post: 755990" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Yes. See more details here:Is it a rule now?
Can you cite your source?Up to 400’ unless you are flying within 400’ up the side of a structure or terrain, then its up to 400’ directly above that.
That is only under Part 107. Recreational pilots have a hard 400 foot rule under the FAA Reauthorization Act that passed last year.
So it’s 400 feet above where the controller stands (on the ground)? Wow I didn’t realize that, my bad!
Well, not exactly. It's 400 feet AGL (above ground level). If you are actually flying over terrain that has a different elevation, then you can rise to 400 feet above that piece of earth.
Yup... so legally, if you fly 10' away from a cliff and go up past 400' you are illegal. As if this creates any problem. However, I can see where a line needs to be drawn.
What you can not do as a recreational pilot is fly 400 feet above the top of buildings or towers. Part 107 pilots have that "freedom" (absent any limitations of controlled airspace), but recreational pilots do not.
Once you move from over the cliff edge, if the cliff is 400’ high you wouldn’t even need to go up more than a foot to technically outside the rule.
I agree about difference it would make, unless flying a reasonable distance from the edge, so yes the line was drawn where it can be clearly known, most likely.
this is one of the issues that i come up against whenever i fly where i live in Wales,there are not many places to fly that are reasonably flat so if i am flying in mountains say i take off and go up 50ft once i go out to say 500ft I could be more than 250 ft up and it is very difficult to really know what height i am actually flying at,and in some instances,if i follow the terrain i can find the height display on the screen is showing a negative figure from where i actually took of from ,at best i can only hope that i am complying with the rules the best i can
