- Joined
- May 27, 2017
- Messages
- 14,460
- Reactions
- 19,472
- Location
- Los Alamos, NM
- Site
- www.mavicpilots.com
From how I read this in essence the FAA is grounding all non commercial drones.
If internet is required I guess you can fly in your front yard unless internet is needed all the time. Net no internet connection will allow this over any distance and height.
Also as previously mentioned how will you be able to fly in National Forest or remote areas that currently have no restrictions? You can’t establish a internet connection in the field.
Lastly this implies that all current drones sold by DJI would not work as none have any built in remote id capability that I know of. Sure DJI says this can be added via software but not sure how easily this will happen.
Big issue for me is fact that most folks places currently fly don’t have internet thus no remote id via software or built in would work
Also most internet works are locked. There are not public networks for flying. So you are going to be limited to your front yard.
Sad day.
Paul C
This is getting ridiculous. That is not what the proposal says at all. It does not rely on an internet connection:
a. Standard Remote Identification UAS
For purposes of this proposed rule, a “standard remote identification UAS” is a UAS with remote identification equipment capable of both: (1) connecting to the internet and transmitting through that internet connection to a Remote ID USS; and (2) broadcasting directly from the unmanned aircraft. Standard remote identification UAS are discussed further in section X.A.1 of this preamble. Any person operating a standard remote identification UAS would be required to ensure:
- · The UAS was designed and produced to meet the minimum performance requirements of the rule using an FAA-accepted means of compliance for standard remote identification UAS. Persons would be able to meet this obligation by ensuring that the serial number of the standard remote identification UAS is listed on an FAA-accepted declaration of compliance. A person operating a UAS would be able to read the label on the aircraft indicating whether the UAS is a standard or limited remote identification UAS. Additionally, a person could determine whether the UAS is listed on an FAA-accepted declaration of compliance by verifying the status on the FAA’s website. The standard remote identification UAS broadcasts the remote identification message elements directly from the unmanned aircraft from takeoff to landing.
- · When the internet is available at takeoff, the standard remote identification UAS connects to the internet and transmits the required message elements through that internet connection to a Remote ID USS.
