FCC mode on Mavic 2 Pro possible?
I brought it to an Ipad mini with ios 11.4.1
Superimpactor was started and i only went to Device
And than : install from ipa
took the latest frida version
Apple Id : e-mail adress
Password: generated apple id
First try with fault
second try stucks for a while but ended succesfull
Kind regards
Same as me!
Hey Guys,
thanks so much for the help and patience :)
it works like a charm! i am currently on an iphone 7 plus with 11.3 -- jailbroken. the jailbreak didnt help me in any way.
what i can tell you is:
1. deactivate that stupid 2 factor authentification **** from apple
2. download all the tools and files:
- superimpactor
- the modded iphone/ipad app called --->> DJI GO 4 4.3.3-frida.ipa <---- that is the modded version
- download the dji-ios-frida-tweak-master.zip file ---- this should include the important file " Tweak.js "
3. use superimpactor to install the the DJI GO 4 4.3.3-frida.ipa
IMPORTANT: it will ask your for a new app name (optional) =>>> put any name inside if you want the normal DJI app to be working as well!!!!
in total 9 steps - this takes a while.
4. start the DJI GO 4 4.3.3-frida.ipa app on your iphone or ipad and click everything through (email and password etc.) it might ask you about the fcc mode , boost and channel 32- if not dont worry. just click through the assistant. once you re done close the app again. and go to your computer
5. start itunes and connect your iphone/ipad to your computer
6. copy the tweak.js and the other files from " dji-ios-frida-tweak-master.zip " (use winrar or winzip to extract) to you DJI GO 4 4.3.3-frida app !!!
7. synchronize your computer with the iphone/ipad so the files are copied!!!!
8. go into flight mode!!!! only then start the DJI GO 4 4.3.3-frida app on your phone and you re done!!! enjoy!!
here is the proof that it worked for me!!! View attachment 49436
Clearest instructions so far, thank you.
I'd add:
- If you've gone too far with all your Apple updates you may not be able to de-activate 2 factor auth. Just create an app specific password to get around the problem.
- Took my 3rd PC, an old Windows7 to get SuperImpactor not to fail. I was getting 'underlying connection closed' with a .NET dialogue crash report. Still haven't got to the bottom of but disable firewall, UAC, AV, run as admin, all that stuff.
- Roll back to itunes 12.7.3 but look after your .itl file - Google
- everything else was trouble free
Locked and loaded for flying tomorrow. I hit a hard stop between 950-1100 metres so I'll know instantly if it's worked.
Reactions: therealalex21
I'd add:
So how did it work!???? did it work??? greetings!
its works fine when i work by this steps:
1.Turn on the drone first
2. Turn on remote
3. Open patched Dji app and set the parameters you wish to activate.
* turn off wifi if you nearby a wifi network
* if still not work, some times its helps just to minimize the app to background for 2 sec and bring it back again.
seems the order is not the fail safe rule, but i tried minimizing it and bring it out again, eventually it will work, one or a few times later
Reactions: Lucagatto
Which Drone did you fly with the Frida.ipa ?
As of the APAS icon on the screen it might be a Mavic-II?
Yup, Mavic-II Pro with DJI GO 4 4.3.3-frida.ipa and 1.01 base firmware in the M2. Activated the FCC mode only, No Boost, rest defaults.
How to Install the patched Frida DJI Go4 App on iOS devices
  • Install Super-Impactor ( http://superimpactor.net/release/1.2.1/SuperImpactor.msi )
  • Download files and unpack if required
    a) Most recent patched Frida iOS Application (*.ipa)
    Index of /Go4_Frida
    b) Frida Repository
    ddzobov/dji-ios-frida-tweak
  • Generate an App specific Password for your Apple ID
    ( Using app-specific passwords )
  • Open iTunes and connect your Device by USB cable. Don’t close iTunes.
    Ensure that your device does not go into SleepMode (iOS Settings App).
  • Disable WIFI on your iOS Device, to enable a sound data transmission for Super Impactor
  • Open Super-Impactor
    Menue: à Device à Install from IPA
    Apple-ID YourAppleID
    Password: YourAppSpecificPassword (Not the Password of your Apple ID !)
    New App Name: DJI Go4 Frida (.. or something else)
    Clone App: / No
    Click Install (it takes several minutes until steps 1..9 have proceeded,
    Sometimes I got an error between step 2/3 but it still worked)
  • Enable WIFI again on your device
  • Switch back to iTunes again
    Click on FileShareing and select the patched DJI GO Frida App
    Click Add File.. and add this 2 files
    - Tweak.js
    - dji-ios-frida-tweak-master"
    Click Sync
    Click Done
  • Open the Settings App on your device
    General à Device Management à YourAppleAcount
    Click Trust to trust the patched DJI GO frida app
  • Open the patched DJI GO Frida App
    - Go through
    the processes of initialization, Tutorial and Aircraft/Remote connection
    as you already did it for the Original DJI Go App
    - Select between the options
    that the patched DJI GO Frida App offers (FCC, Boost, Channels)
Great description! Thank you!
After seven days, the same procedure must be repeated for license renewal (Apple ID) or is it easier?
Greetings
Where can i find a signalstrength indicator in the DJI Go4 App that indicats me wether i‘m in CE or FCC Mode
.... Connecting to a MP2!
check the line on signal quality window. If above 90dbm, you are in FCC Mode. Tried boost too, it still same line above 90dBm.
The boost is very strong signal. Flying perfectly 6KM at Dense City
Thx
I simply did not found the signal quality window within the App.
In several YT Videos there is an icon in the DJI GO4 App linking to the signal strength display (looks like a WIFI icon). Most Videos are for the spark or Mavic Air
i don’t see this icon when I connect my M2 Pro.
Just noticed that it is behind the icon named “HD”
deepdark
