Finally up and running with Mavic Air and Crystalsky
Thanks a million for posting this
Good solution, I was thinking of doing that but I didn't want to cut anything
Does the mount still work with the other controllers like the MP or MPP or Spark after making that modification to the mounting bar ?
I took a slightly different approach and swapped the jaws out of my Spark controller into my MA controller. I figured I was going to use the MA more with the CS than the Spark. The whole process takes a few minutes where you have to remove the 4 screws.
Yes the bar should work but it will probably float about a bit and may be a bit fiddly to locate with the screws.
I thought of getting a couple of replacement jaws to cut in to but I don't think that they are available....
I recently sold my Inspire, Phantom 4 Pro, Mavic Pro and Spark .... So at the moment I only need to keep the Air happy.
Reactions: ant104
deepdark
