Florida Man in Pensacola
MartMX
Pensacola, FL
Done R/C airplanes on and off for decades. New to DJI. Just got an Air 2S - this thing is fantastic. Mainly plan to take it on jet ski trips to video the ride and look out for sharks on private beaches.
Welcome to the forum! :)
Thanks, guys. I'm reading on here about the necessary training, rules and regulations. It's a new feeling to fly something by first-person view, have it actually get out of sight, perhaps out of range, and it come back and land by itself.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
Please read all the rules carefully as you are not allowed to fly it out of sight…
Reactions: wjkrysak
10-4. I live sort of out in the country, and flew it behind the tree line. But, I'll get on those rules this weekend.
Thanks for all the info.
Reactions: LoudThunder
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Welcome to the wonderful world of drones. As you already know, there is a big difference when flying R/C planes compared to drones.
I fly my drones over in Perdido Key as I enjoy winters there. Lots of great places to fly there. Have fun!
peehead
