From Southwest Germany
Michael Volkert
Germany
Hi, I'm Michael from Southwest Germany (German/Swiss/French border area). I'm completely new to flying drones. Have bought a Mini 4 Pro recently but had no chance to fly it yet due to weather constraints. Catching up with theory and the rules in the EU in order to pass the EU equivalent of the part 107 exam. Also interested in drone technology. Looking forward to some interesting exchanges and discussions.
Welcome to the forum! :)
Hello from the Crossroads of America Michael Volkert.
Nice to meet you Michael. 🤝
Welcome to the Forum. :cool:
Welcome to the MavicPilots forum. Enjoy safe and happy flying, and have a fantastic 2024!
Since you live in Germany, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
anton13
