G'day from Perth
Welcome to the forum from Hauptmann in North Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro. Don't know where you're travelling, but if it's UK or EU, you might consider installing the FCC hack (for about 40 USD), which will give your drone FCC range in all countries.
Our more than 150,000 members worldwide--including many, many Aussies--enjoy helping each other get the most out of our hobby. Most questions you'll likely have will've already been addressed in previous posts, and are easy to search. New questions? Just ask!
Glad to have you as a member!
Rich R (aka Hauptmann)
Welcome to the forum. We look forward to your participation and your view of the world.
I've only been flying for a while
You say you've "only been flying for a while", a "short while" or a "long while?"
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
erhard
