mavicpilots.com
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
According to CASA, drones are allowed in Australia for recreational and commercial use, subject to CASA regulations. Read on for details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic 2 Pro/Zoom, including the User Manual.
At DJI Download Center, Learn aboutMavic 2
www.dji.com
Happy Droning…
