Glitch with stitching in the drone . Panovola same but different.
Shuttersky597
Fort Walton Beach
I noticed a glitch in the vertical columns on Air 3 and using panovola. Not sure what caused this. Same glitch in different areas.
Has anyone else seen this? Though it was a photo glitch, but individual pictures look fine. First is within the drone. Second is with Panovolo
Contact @PanoVolo for help
Reactions: sarahb
Hi @Shuttersky597 - edited the post, I see what you mean. This is a parallax error due to the drone being close to the building. Some shots were focused at closer distance, some further out and that caused a stitching error.
Generally for good panoramas try flying a bit further away so that all shots are focused at infinity.
You can try to correct this error in PanoVolo, follow this guide
Try adjusting the "yaw" of images in the center by very small amounts, 0.01 deg, rendering a new panorama and checking the error.
Reactions: Shuttersky597
libanczyk
