Goggles compatible with Mini Se Under $200
Etbrown4
USA
Are there fairly good goggles which will work under $200?
Any special cabling or wifi requirements?
I was considering the fat shark scout, but know little about it.
There is nothing that's compatible with a mini se, would have to use one of the many more or less kludgy workarounds.
I've seen two adapted skillfully to the mini or se.
One uses the Uneec Skyline headset at $159. This ebay seller tells you what you need to adapt, including a $25 wifi dongle, maybe 2 cables, and a small battery.
I've seen another setup where they used dji goggles and about the same connections.
Am interested to learn about other successes, how well they work, and if anyone has used the Fat Sharks.
DJIMavic3cine
