Greetings from Dana Point, California.
DennyCrane
Dana Point, CA, USA
New owner of a Mini SE and made the first flight this morning. First project is to photograph and video my roof, prior to and during installation of solar panels. Learned that I need to stick with VFR after flying it into the back yard and backing it up into my neighbor's 70' tall pine trees. It was undamaged, and landed conveniently in a tall bush within reach over the fence.
Greetings from Birmingham Alabama USA, welcome to the forum!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California , there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you have already had your first Scary Moment, here is some Good Old Fashion Advice that might keep you from repeating your mistakes…
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Happy Droning…
Hello from the Crossroads of America DennyCrane.
Welcome to the Forum. :cool:
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome to the forum! :)
Greetings from Colorado 🇺🇸, welcome to the forum🎄
Hollywood52761
