Greetings from Plano, TX
Saxguy
Plano, TX
Hi everyone. Thanks for letting me a part of your community. I am a freelance photographer and wanted to get into drone photography to complement my skills by getting a "higher perspective" on images and eventually video. I am a new drone operator with a DJI Mini Pro 4. Already seeing great views!
Welcome to the forum Saxguy from Plano. Safe Flying!
Welcome to the forum! :)
Hello from the Crossroads of America Saxguy.
Welcome to the Forum. :cool:
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
HOWEVER… You wrote that you are a "freelance photographer" which indicates that you take photos and videos for compensation, You must realize that any photos/videos you take with that drone may only be taken for pleasure, if you intend to sell or take photos/videos for income, you must have a Part 107 license and you will be required to register your drone… That's all I say and not harp on it any more…
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome, Saxguy. I’m also in Plano, TX. Let me know if you’d need to know some good flying spots. Check out this Meetup group for other photographers/videographers.
North Texas Drone User Group
Greetings from Chicago the Windy City, welcome to the forum.
FLY SAFE & FLY SMART
Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!
Reactions: wjkrysak
Keith J
