Greetings from Romania!
I’ve just purchased a Mavic Air 2 drone. I have no experience at all,
Since you live in Romania, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2, including the User Manual.
Fly On and Fly Safe…
Greetings from Romania! I’m new here and I’ve just purchased a Mavic Air 2 drone. I have no experience at all, but a lot of desire to do beautiful things.
So, thank you from the beginning for your advices, because I will definitely need them.
Hello and welcome! Where in Romania do you live? I have visited Bucharest, Iasi, Cluj, Brasov, Constanta, and several other cities.
Welcome to the forum! :)
peehead
