Greetings from the Phoenix, AZ Valley
Hello from the Crossroads of America iphotochop.com.
Nice to meet you Bob. 🤝
Welcome to the world of aerial photography.
If you haven't done it yet, swing by the FAA and register the aircraft.
You should take the TRUST test and keep a copy with you when you fly.
Welcome to the Forum. 😎
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Reactions: MA2 317 and GFields
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello. I’m a new member also. Perhaps you could steer us to some good drone friendly places in AZ? I’m thinking of visiting the Phoenix area this fall.
Reactions: GFields
Combining my love of photography and aviation with a Mavic Air 2s
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs over 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Arizona, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Welcome to the forum. We look forward to your participation and your view of the world.
InspectorTom
