Greets from Oregon
Welcome to the forum! :)
Flew a friends DJI drone last week and was hooked. I have ordered a M3P
As a soon to be New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . The M3P weighs less than 250-grams (0.55 pounds) with the small batteries and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Because you have just started flying drones, here is some Good Old Fashion Advice to get you started…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Thanks for all the great information. Did the trust certificate and waiting for the drone to arrive tomorrow.
While you wait, go watch some YouTube videos, it will take the edge off of the anticipation...
And while the batteries charge, handle the drone, get use to how it's legs open, how to remove the gimbal cover, get use to the controller and which controls control what functions.
And Breath, take deep breaths before doing anything. Be sure you are not in your house the first time, do it out in the open and not under a tree,
Read my welcome post again, take your time. There is nothing more disheartening than crashing your drone on your first flight...
FLy Safe!
Reactions: wjkrysak and RodPad
seaphotos
