Hacking max altitude on newer Mavic Pros fail
trelliz
Moscow, Russia
I have just learned the hard way that newer models of mavic pros (with initial 1.3.1 FW or newer) cannot be simply downgraded, but must also be disassembled and an extra micro sd card must be inserted in order for the drone to work. Otherwise you will get "cannot take off message" and sd card error message.
It was also discussed on reddit: Suggestions please! Mavic pro is locked and cannot take off after mod • r/DJIUnlocked
You would be correct.
I found this out by trying to revert the firmware, and having it unable to fly, THEN doing my research... :(
But I was keen to keep the reverted firmware, so undertook the disassembly to insert the SD card. Wasn't too hard - there's a few videos around on how to disassemble (only do the top shell, you don't have to remove the lower casing!). The most difficult/time consuming/stressful part was removing the silicone-type stuff from the empty SD card socket, and working out how to open the tray. Again, research and Youtube are your friends...
Happy to dig out the specific references I used, if you're keen to do it... otherwise you should be able to revert to more recent firmware to get a flying bird again (I did, before I had a go at it again).
Good, make it harder. Hell, I'd be all for DJI detecting it and completely shutting down the aircraft unless you submit a reason as to why you're trying to do it.
smittysflying
