HD-Mode or regular?
Stickybit
Nieuwegein, the Netherlands
Hi all,
Yesterday I spoke to a fellow drone pilot about the Regular and HD-Mode which can be switched within the settings of the Smart controller.
I read somewhere you experience less range issues when using the regular mode. When I switch I see the bandwith used drop from around 11 Mb/s to 6 Mb/s. So I think it’s fair to say it uses less and should help on bad connections or connections which should travel longer (flights from 1 Km away and up).
Does somebody know which setting is better for range?
HD-Mode will show a better picture on the screen, so if it’s not affecting the range I will stay with HD :)
Reactions: m2zAL
HD mode uses a higher bandwidth communication which makes it more likely to fail when the signal gets weak.
Reactions: Phantomrain.org
Treknotika
